Yesterday I attempted to twice post some questions about the Beosound Moment as it is now available in America. Both posts were blocked as needing moderation. Still nothing. what was wrong with the posts?
I have tried rewording and changing the post multiple times and every time it is blocked. Very annoying. Even tried just posting the first sentence describing the Bang and Olufsen items I have and it was blocked.
The Moment was recently made available in the US and I am considering one.
However I am somewhat confused about how it would work with my system and have some questions. I hope someone does not mind answering them.
I have a BV7-55 with attached speakers and a BV10-40 with attached speakers.
I have a BV7-55 with attached speakers and a BV10-40 with attached speakers. They are connected with Masterlink along with a Beosound 5.
There is another Masterlink connection available in a third room which is where my router is I also have a stand alone Beoplay V1.
My questions are:
1. Do I need one or two NetLink converters to be able to access the Moment through the BV7/speakers and BV10/speakers?
2. Does/do the converter(s) need to be connected to the BVs, or if only one is needed, could I connect it to the Masterlink in the third room?
3. Once the Moment is connected, if I wish to listen to music, must I turn the Moment using the Moment, or can I use the Beo 4 to turn music on as I do with the Beosound 5?
4. Will the Beoplay V1 connect in any manner wirelessly to the Moment or will the two remain completely separate?
5. Any comments on sound quality of Spotify on the Beosound 5 compared to Deezer on the Moment?
6. I have heard that in a couple months Deezer will make Elite available to all Deezer subscribers, not just those with Sonos system. Is this true?
Thank you in advance.
Apparently everything in the posts I attempted is acceptable to be posted in bits in this thread but not acceptable in two existing Moment threads as well as a new Moment thread I tried to create? Very strange
These were the questions that have been repeatedly blocked in Moment threads.
Razlaw: 2. Does/do the converter(s) need to be connected to the BVs, or if only one is needed, could I connect it to the Masterlink in the third room? 3. Once the Moment is connected, if I wish to listen to music, must I turn the Moment using the Moment, or can I use the Beo 4 to turn music on as I do with the Beosound 5?
These were the questions that have been blocked in Moment threads.
These were the questions that have been repeatedly blocked in other threads.
In this thread apparently the same questions can be posted without being blocked?
Only blocked in moment threads where they belong?
Final question was:
I also attempted to post yesterday asking a question about speaker choices, I should have copied and pasted it because when I clicked post, I got a moderated post notice, and i haven't seen it on this site. Now I Have to recreate the post, which, for my posting habits was rather long. You're right, very annoying.
Sorry I can't help you with the Moment questions. I'm also in the market for a Moment, but all I have are NL products at the moment (pardon the pun).
Sal and Razlaw,We have an automated filter, that sends what it considers suspicious to moderation.The criteria are not always quite clear but both of your original posts containsseveral bullets, which may have trigged it.Repeated similar looking posts may also trig the filter, as may posts containing the same word too many times.I approved your posts,Sal, yours can be found here:http://archivedforum2.beoworld.org/forums/t/16598.aspxRazlaw, yours here:http://archivedforum2.beoworld.org/forums/t/16596.aspxMartin
Regarding moderation here in the forum. It's broken. Trying to report a post as spam get a could not be found. Can you please look into this.
Dillen: Sal and Razlaw,We have an automated filter, that sends what it considers suspicious to moderation.The criteria are not always quite clear but both of your original posts containsseveral bullets, which may have trigged it.Repeated similar looking posts may also trig the filter, as may posts containing the same word too many times.I approved your posts,Sal, yours can be found here:http://archivedforum2.beoworld.org/forums/t/16598.aspxRazlaw, yours here:http://archivedforum2.beoworld.org/forums/t/16596.aspxMartin
Thanks for the explanation although it does not make sense. The questions were as generic and B and O related as possible. Also, the language was cut and pasted into this thread and the filter allowed it. It would be interesting to know what items were offensive to the filter. Verbs? B and O products? Numbers? Punctuation? Then the entirety of these individual posts was cut and pasted into other threads and again the filter allowed it.
If the offensive items were made known it would save future aggravation of having posts rejected for no apparent reason as the poster could refrain from use of whatever the offensive words were.
I have had similar problems. There have been some changes to the forum that just don't work and have made the forum very frustrating. Using Safari, I can no longer edit my posts. Also, the method of posting photos first in the Media Gallery and then trying to access them to put into posts does not work. I see no reason why we should not be able to simply upload a photo directly into a post the way we once could.
If I want to do anything more than post. I kick it over to Chrome using the "Develop" menu in Safari in OS X.
BeoNut since '75
- Again threads with several bullets. That could be it.
I have no influence on the filter setup and it doesn't tell why it sends a post to moderation, I can only guess.
Dillen:- Again threads with several bullets. That could be it. I have no influence on the filter setup and it doesn't tell why it sends a post to moderation, I can only guess. Martin
I did that a couple of hours ago. Can't you see them ?
http://archivedforum2.beoworld.org/forums/t/16595.aspxhttp://archivedforum2.beoworld.org/forums/t/16596.aspxhttp://archivedforum2.beoworld.org/forums/t/16598.aspx
Dillen:I did that a couple of hours ago. Can't you see them ? http://archivedforum2.beoworld.org/forums/t/16595.aspx http://archivedforum2.beoworld.org/forums/t/16596.aspx http://archivedforum2.beoworld.org/forums/t/16598.aspx Martin
Simple one sentence post has just gone for moderation.
All very tiresome for both Beoworlders and Moderators. Do the auto filters need some adjustment?
Graham
I cannot see, why your post was sent to moderation.I have approved it.
Dillen: I cannot see, why your post was sent to moderation.I have approved it. Martin
Thanks Martin.
