I was just wondering about the Beolink NL converter in a multiroom set up. You can connect speakers to the converter and even join in a source using the eye. But can you use the beomusic app and stream directly to it so it would be possible to play different music?
Toby
As far as I have understood: you can. But any confirmation on this would be great.
badgersurf:Hi, I was just wondering about the Beolink NL converter in a multiroom set up. You can connect speakers to the converter and even join in a source using the eye. But can you use the beomusic app and stream directly to it so it would be possible to play different music? Thanks Toby
Thanks for the answers, makes planning my new layout a bit easier
