Help needed! Masterlink problem
This post has 8 Replies | 0 Followers
parasound
Sweden
Posts 69
parasound Posted: Tue, Sep 22 2015 5:47 PM
Hello Beoworlders!
My wife recently noticed that  the BS3200 in  our living room don´t react with the Beo4 remote.
Don't now what´s wrong? it´s connected to a Beovision 4-50 (Beosystem 3) that works fine with video-command (a.tv,dvd/bluray,dtv), but nothing happen with audio-command (radio,a.mem,cd, a.aux)
But in our lounge we can control the BS3200 with no problem and get the sound to our Beovision 3-32. In the living room the Beovision is set to option 2 and the BS3200 is set to option 0.
The thing is that we haven't change anything, so we don't understand why this have happen. We have also unplug all the mains, still the same problem.
Anyone know what might happen?
Living room: BeoVision 4-50 ACM, Beosystem 3 MK3 with samsung SP-H710AE projector, BeoLab 7-1, BeoLab 6000x3pair, BeoSound 3200, AV & CD cabinett & Beo4.
Lounge: BeoSound 3, BeoVision 7-32 mk5 & Beo4
Kitchen: BeoLab 2000 & Beo4
Master bedroom: BeoVision Avant-32, DVD1, BeoSound Ouverture & Beo4
Guest room: BeoVision 4002, DVD1, BeoSound 2000 & Beo4
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Tue, Sep 22 2015 6:01 PM
Hi
You state that the BeoSound 3200 is in option 0. This is the correct setting if it is connected to BeoSystem 3 and you have NO speakers connected directly to the BeoSound 3200.
When in option 0 you disable the infra red sensor as you need all ir commands to be routed via the video master, in this case your BeoSystem 3.
Can you unplug the Masterlink cable between the BeoSound 3200 and BeoSystem3 whilst the system is powered off. If you can't try another Masterlink cable, re-insert the existing one and ensure it is fully plugged in before powering up the system again.
Opman
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Tue, Sep 22 2015 6:03 PM
I forgot to ask in first reply, what option programme have you set the BeoVision 3 in? This should be option 6 if it is link TV with access to audio as well.
Opman
parasound
Sweden
Posts 69
parasound replied on Tue, Sep 22 2015 10:45 PM
Thanks Opman!
I have tried all the things you told me, but with no luck Sad
3 hours ago, me and some friend were going to se a movie (the burning) oldie but goldie Big Smile and the beosystem was completely dead, not even a red standby lamp. I still have warrenty on the BS3 so no big worry, but very annoying and don't feel very safe for the future Crying
Unplugged the mains again, but nothing. And then suddenly it start to work, even the BS3200 now play everything. Strange, but glad we could se the movie, and now I'm enjoying my music again Big Smile
But i think i have to talk to my dealer about what he thinks of this.
Thanks again Opman Smile
mjmedlo
Posts 922
mjmedlo replied on Wed, Sep 23 2015 3:49 AM
parasound:
Thanks Opman!
3 hours ago, me and some friend were going to se a movie (the burning) oldie but goldie and the beosystem was completely dead, not even a red standby lamp. I still have warrenty on the BS3 so no big worry, but very annoying and don't feel very safe for the future
Thanks again Opman
Lounge: BeoSound 3, BeoVision 3-32, DVD1, AV cabinett & Beo4
Open a repair case with the dealer.
This MAY extend the warrantee
parasound
Sweden
Posts 69
parasound replied on Wed, Sep 23 2015 7:42 AM
Thanks mjmedio!
I will do that and hope for the best Smile
Millemissen
Flensborg, Denmark
Posts 14,680
I'd say: a faulty MasterLink connection.
parasound
Sweden
Posts 69
parasound replied on Wed, Sep 23 2015 3:42 PM
Could a faulty MasterLink connection make the beosystem3 not work?
Millemissen
Flensborg, Denmark
Posts 14,680
I have had all kinds of odd things going on in a setup, when there was a 'faulty' ML connection somewhere.
Listen to what Opman wrote above - he is someone, who knows about these things.
Check (and double-check) your ML cable(s)/connections/junction-boxes!!
Page 1 of 1 (9 items) | RSS
