Hi I can see by the listings under Beovision8 40" that there are wall brackets out there for £130 not 530 that Stbrackets want to charge. I have hunted for them and I have been unsuccessful please help
Ta Jono
STB Brackets also has a fixed wall bracket for around 160GBP. I do have such one in the 8-32 version and like it. You can twist the screen. Very stable solution, very good service.
BV 11-46 / Beoplay V1 -40 / Apple TV 1+3 / Beosound Essence MK2 / BL3 / 2* BL11 / BL 6000 / BL 12-1 / BL 2000 / 3 * Beo4 /BL Converter 1611
If you wan't it even cheaper here is my solution from the old forum
http://archivedarchivedforum2.beoworld.org/forums/t/35050.aspx
