Beomaster 6500 not receiving IR from mcp 6500
Robert
Finland
Posts 16
Robert Posted: Fri, Sep 25 2015 8:27 AM
Hey!
I believe my remote mcp 6500 works because i see the red lights flash while pushing buttons and then it says no contact.
The problem is the beomaster which doesn´t turn on at all. I have a technician that has measured here and there and i believe he said that the boards get power but the on button doesn´t work or the IR Eye doesnt receive?
Some caps bad or?
Which level of membership gets me the service manual for beomaster 6500?
Thankfull for any advise!
Robert
RaMaBo
near Munich
Posts 626
RaMaBo replied on Fri, Sep 25 2015 9:56 AM
Hi Robert,
a silver mebership gives you acces to the complete Manual section. A gold membership gives you addtional the possibility to win in every of  the 4 prize draws each year.
Ralph-Marcus
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Sep 25 2015 3:20 PM
Is the red standby dot lit on the Beomaster ?
Robert
Finland
Posts 16
Robert replied on Fri, Sep 25 2015 3:54 PM
Hey and no, the red standby doesn't lit up.
I currently struggled thru my older emails and found a message from you Martin :)
There you suggested i would " check the reset circuit for function and the power supply to the processor for ripple and correct voltage".
I will let the technician do that and get back to the forum when we made progress.
Robert
Page 1 of 1 (4 items) | RSS
