Beomaster 5000 zero No load current
yiancar
Posts 18
yiancar Posted: Sun, Sep 27 2015 12:18 PM
So one of the channels is working just fine, the other I measure 0mv, is the potentiometer dead or should I check for anything else too?
Also the base of both ic200 and ic201 is about 0.1v which is too low compared to ic100 ad ic101 which is about 1.1v
edit2: between diods d203 and d201 there should be about 1.7 v, which i got in the working channel but only about half of it  on the non working side
Yiangos
yiancar
Posts 18
yiancar replied on Mon, Sep 28 2015 7:46 PM
Soldering on the output transistors, solved:) Thank you Martin
yiancar
Posts 18
[please delete]
Page 1 of 1 (3 items) | RSS
