Hi Esko,
the Datalink should work with the pin in either position 6 or 7 according to past posts. You can transfer the pin and see if it works though. Don't lose the pin. It's easy to do! More often than not, the pins 6 and 7 are either both there are both missing. If you only have 1 pin, try swapping it over.
Welcome to Beoworld by the way.
Dave.
Have you modified anything of this, or are you using an external RIAA?
The BM4500 does not have RIAA, nor does the BG9500.
