Kai,
there ain't CAT7 cable outlets as the RJ45 Plugs simply don't fulfil the CAT7 requirements - the pin distance is too narrow so they have too much cross-talking.
There are CAT7 sockets but not with a RJ45.
Had the same issue some time ago - I did use CAT6A or CAT6e which are the "best" ones still using RJ45-connectors.
Gunther
