Hi all.
I do have 2 Beosound 9000´s, one of them is Type 2561 and the other one is Type 2571.
Is it possible to swap the CD units, i was thinking like connectors and other stuff ?
One of them has a fully functional cd unit but a faulty lid opener :(
The other one has fully functional lid opener but a faulty cd unit :(
Or should i just get them both repaired by a shop as i am kind of clumpsy sometimes.
/Basstard
Basstard: Hi all. I do have 2 Beosound 9000´s, one of them is Type 2561 and the other one is Type 2571. Is it possible to swap the CD units, i was thinking like connectors and other stuff ? One of them has a fully functional cd unit but a faulty lid opener :( The other one has fully functional lid opener but a faulty cd unit :( Or should i just get them both repaired by a shop as i am kind of clumpsy sometimes. /Bassatard
/Bassatard
Mk2's, and possibly mk1's could have the cd replaced with mk3 cd units, but the drive and suspension are different, so the upgrade kit came with other springs and a complete new drive.
if it is the MK1 that has a defect cd drive, then it needs a new CDM 12.4 laser, which can still be found. If it is the MK3, it needs a laser that is not possible to get, unless buying from B&O.
What is wrong with the lid ? Belts should be possible to get and replace.
If you cannot do it your self, I think the price of letting a dealer or service place do it, will be pretty high.
/Weebyx
