I know this is a dumb question, and I am sure I have done it before......but have not used for awhile and can not get it to work today.....how do I get a Spotify playlist to play on the Beosound 5? No matter what I I try, it only plays one item in the playlist and then switches to something else.
thanks
Hi Razlaw,
I don't have my BM5/BS5 set up at the moment so I can only make a suggestion from memory - but the general rule for the BS5 is that if you press play (GO) when the 'container' (be that an album, playlist or whatever) is selected, that will be played in its entirety, whereas if you press GO whilst a particular track is highlighted (usually the first track on an album when I do this by accident) only that track is played.
Might not be what is causing your issue but it's the most obvious reason I can think of without checking it first hand.
Kind Regards,
Martin.
