Wireless setup help
This post has 1 Reply | 2 Followers
Rasmusen
Posts 1
Rasmusen Posted: Sat, Oct 10 2015 3:28 PM
Hi everybody
Today I have a V1 with 8000 as front speaker. I want a pair of 4000 to work as the rear speakers, but without cables around the room.
I have considered this solution http://www.tp-link.pt/products/details/cat-18_TL-PA8030P-KIT.html
instead of the more expensive wireless transmitter/receiver from B&o.
Do anyone has experience with moving speaker signals through such a solution ?
Will it be able to operate without delay and noise from other electrical parts?
Thank you for your answers
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Sat, Oct 10 2015 3:37 PM
Rasmusen:
Hi Rasmusen and welcome to beoworld.
The device you have found will not work for this use. Whilst the cables / RJ45 plugs might look the same, the TP Link device is designed to convey data (ethernet) signals over the mains wiring. The signals in the Powerlink cable are analogue audio signals.
Is there no chance of being able to fish the cables within the walls, behind skirting boards, under floors etc?
Kind Regards,
Martin.
Page 1 of 1 (2 items) | RSS
