NL convertor update
This post has 9 Replies | 2 Followers
Seanie_230
UK
Posts 2,278
Seanie_230 Posted: Sun, Sep 27 2015 4:28 PM
Hello all
My NL convertor said it had an update to do so I attempted it.
It said failed to contact update server.
A reboot was in order
Now it just says update status Unknown
Any ideas?
Is still works fine by the way
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
mjmedlo
Posts 922
mjmedlo replied on Sun, Sep 27 2015 4:52 PM
No update on mine.
Chris
Ostend-BE
Posts 1,170
Chris replied on Sun, Sep 27 2015 4:58 PM
Hi seanie,
Mine is still on 1.4.1, no update (on a sunday?)
Is your gateway & DNS servers correctly filled in on the system/network tab?
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
BeoMegaMan
Posts 601
BeoMegaMan replied on Sun, Sep 27 2015 10:14 PM
Is you BLC time set to the same time as your router? I've seen issues in the past with that symptom. There isn't a new sw push past 1.4 that I know of. If the correction of time doesn't fit the trick you will have to reset to default. The only other way I've cleared the problem you suggest.
Ah, you know... A little B&O here, a little there
Seanie_230
UK
Posts 2,278
Hello there
Yesterday I noticed that my convertor is not doing anything.
Rebooting it does not work.
The date on it says June 2015 so it seems to be a little odd.
I cannot see anywhere to update the time manually.
How do you reset it?
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Chris
Ostend-BE
Posts 1,170
Chris replied on Sun, Oct 4 2015 8:22 PM
Could I be of help with the setup manual:
https://www.dropbox.com/s/gle62x40f71oz7s/BLC_NL-ML%20Installation%20Guide%20Ver.%201.2.pdf?dl=0
Seanie_230
UK
Posts 2,278
Thanks for your help with the manual.
I had to search for how to factory restore as it would not do anything.
As soon as I restored it a software update started
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Chris
Ostend-BE
Posts 1,170
Chris replied on Thu, Oct 8 2015 10:24 AM
Hi Seanie_230
There was an update yesterday of the BLC, its now on software 1.4.2.19611
  • This software update includes various performance improvements and minor bug fixes as well.
elephant
AU
Posts 8,219
elephant replied on Thu, Oct 8 2015 12:50 PM
Chris:
Hi Seanie_230
There was an update yesterday of the BLC, its now on software 1.4.1.19611
This software update includes various performance improvements and minor bug fixes as well. "Believe nothing you read and only half of what you see, let your ears tell you the truth."
Applying this update now ...
BeoNut since '75
Chris
Ostend-BE
Posts 1,170
Chris replied on Thu, Oct 8 2015 1:16 PM
Sorry, spelling mistake. It must be update with number 1.4.2.19611 for sure.
It fixed my track choosing problem on the ML also, I can use again the Beo4 up-down button to choose a music track.
Page 1 of 1 (10 items) | RSS
