Hi all,
I have a simpe question. Does Beosound Essence require a specific IR-eye (reciever) or would any do (that is if there are differnet ones)?
It is the same one, that is used for the NL/ML Converter.
The one with the 'join'-button.
Thank you Millemissen for quick reply. It then seems to me that there are other models too. Do you by any chance have information about item/serial number so I can make sure that I get the correct one?
And if I may ask another question, wilI be able to controll the essence with a Beotime?
sia: Thank you Millemissen for quick reply. It then seems to me that there are other models too. Do you by any chance have information about item/serial number so I can make sure that I get the correct one? And if I may ask another question, wilI be able to controll the essence with a Beotime?
Probably only in a limited way. see the B&O FAQ pages:
http://bogo.custhelp.com/app/answers/detail/a_id/2190/~/can-i-replace-my-remote-control-with-beotime%3F
Dave.
Thanks Dave
Sia
