I haven't messed with the monitor circuit on any of my Beomaster 8000 units but the actual switch routing of the audio signal to the output amplifier would have to occur on the preamplifier board. The selection of the selected source does come from the processor board. So I don't think swapping processor boards would change your monitoring function.
According to the preamplifier part of the schematic shown here, if FM, Tape 2 or Phono are selected as the source to listen to, IC202 (AD 10/278) selects the appropriate signal. That signal routes up through IC4 (AD 10/192) where it continues on to the output amplifier. The selected source signal also routes to the TP1 record inputs via IC7 (opamp). If the user wants to monitor TP1, the IC4 (AD 10/192) switch can switch the TP1 outputs to the BM8000 output amplifier without disturbing selected master source signal to the TP1 record inputs.Going the other way, if TP1 is being used as the master source, its output signal is routed through IC4 (AD 10/192) to the output amplifier. That signal also routes over to the TP2 record inputs so TP1 can record to TP2. At this point you wouldn't want the monitor switch to switch TP1 out because that would interrupt recording to TP2. The control signals for the preamplifier signal switching (IC4 and IC202) come from the processor board IC4 (6500/1) Slave. o, q, p and r in the schematic.
I wasn't aware that the monitor function changed on some of the BM8000 units though. I would like to see a picture of the schematic of the other one.sonavor
