Controlling Sky box with Beo4, PUC, BeoVision 11
BE0FAN
Posts 6
BE0FAN Posted: Fri, Oct 23 2015 8:34 AM
I have a BeoVision 11. I use the Beo4 remote and have an IR blaster connected to the PUC port and running to the Sky box.
The Beo4 was controlling the Sky box fine. I think I pressed a button/combination of buttons (or it was merely coincidental) and now the Beo4 doesn't control Sky.
The Beo4 still controls other devices connected by other PUC IR's.
I have tried the following to resolve it:
1) Checked the sky box is still working with the sky remote
2) Reloaded the PUC Code
3) Tried other Sky PUC Codes
4) Powered the TV down for 20 mins
5) Checked the IR cable for damage
Non of these have worked.
Coincidentally, this has happened before and then resolved itself within a few days. But not this time.
Anyone experienced the same or have any advice to fix it?
malcolm welborn
canary islands
Posts 188
hi I have sky hd with beovision 11 had similar problem my aerial man told me take out hdmi cable for 2 minutes then back  worked perfectly worth a try
malcolm
BE0FAN
Posts 6
BE0FAN replied on Sat, Oct 24 2015 10:42 AM
Thanks Malcolm
I tried that but no joy. So i tried removing and reconnecting the RJ45 end of the IR blaster and all good again. Sky controls are working properly.
Page 1 of 1 (3 items) | RSS
