Hi all,
I recently purchased a second hand Bombaster 5. Once i had plugged it all in came the task go setting it up.
As it didn't come with a ripper i need to get my music on it, this can be done via an app called Beoconnect but this needs setting up.
The app wants info that can easily be got from your head unit once powered up and networked.
This is straight forward until it comes to entering a password the is stored in the Bombaster.
Heres how to change the password.
To change the password of BeoSound 5…> Select SETTINGS in the MODE menu> Press the right arrow button twice, immediately followed by GO> Select CLIENT PASSWORD in the NETWORK SETTINGS menu> Turn the wheel to select a letter or digit and press GO to confirm. Repeat the procedure for every letter or digit. Use the right arrow button to delete a letter or digit, if necessary. > When you have made your password, turn the wheel to the bottom of the list to select STORE and press GO.The password of your BeoSound 5 has now been changed.
