Beoplay M3 Functionality
This post has 1 Reply | 0 Followers
Beosince98
Posts 274
Beosince98 Posted: Fri, Jun 29 2018 2:17 PM
I am thinking about getting an M3. I was wondering if anyone could tell me what happens if I press on the Join button on the back. Will it start its last multiroom source, or only the last Bluetooth source. Is the functionality the same with the Essence remote? Thank you for your help!
Hiort
Sweden
Posts 2,895
Hiort replied on Fri, Jun 29 2018 2:20 PM
Yes. If you have a source playing, M3 will join that experience. Next double press and you jump to the internal source that you have set up.
If nothing is playing anywhere, M3 will start the first source you have set up in the source list.
Page 1 of 1 (2 items) | RSS
