My ML do not see my audio master after removing the BS 5, while waiting for my Moment to arrive I wanted to use my PC2 .
I thought that this will be a simple 5-minute operation, taking it out from the box ( I have not using it since I bought the BS5 ) and connect to the ML, to mac mini with BMLink and press Nmusic…………nothing.
Probably this is something easy to solve or ??
The PC2 is working when connecting speakers directly to it, the problem is no distribution in the ML.
When I press CD, Radio Amem2 ,Phono, Nmusik, Nradio………..depending on the equipment in the link rooms it should start but nothing.
Any suggestions.
96 Normal 0 21 false false false PL X-NONE X-NONE
G
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Ok, now i belive that I understand , the PC 2 is not an AudioMaster , its only a box for Nmusic and will not work without a AudioMaster, soo i guest that i have to wait for the Moment or buy a used BS 2500 or similar.
thanks
Which Option was/is the PC2 set to?
2
but is the PC2 a master?
I'd try Option 6, but no guarantee - it is a long time, since I played with the PC2.
And power-on/power-off your masterlinked devices before you start using the setup again.
Gilbert :Ok, now i belive that I understand , the PC 2 is not an AudioMaster , its only a box for Nmusic and will not work without a AudioMaster, soo i guest that i have to wait for the Moment or buy a used BS 2500 or similar. thanks G
