Morning.
Can anyone tell me if a BeoCom2 table charger from Europe (2 pin plug) is compatible for the UK. I know I can use an adaptor but I wasn't sure of the voltage? Have checked my two chargers I have already and there is no voltage rating on the bottom.
It will work fine in the UK
