So I bought a set of second hand Beovox CX 50 and was hoping to get started using them but turns out the foam is damaged so this needs to be fixed. I spoke to the local B&O service company and they told me that they do not do it as its a difficult job and can go wrong easy which will then affect the sound quality. Is this accurate?
He advised buying new speakers and just replacing them, any thoughts?
If the speaker cones are moving freely it is easy to "refoam", search the forum for foam surrounds, refoaming, speaker surrounds or surround repair, follow instructions and it is an easy task.
And welcome to the forum
The CX speakers may not be the most difficult but it can certainly go wrong, if you're not the DIY type.Many failed attempts have ended up on my doorstep with a note crying for help, - I've lost count.
Where are you located?
I've seen a few sets sell in Australia lately sell and all have had foam rot, the sellers seem to think it's not a problem when I question them about it. I generally ask as I'm always looking for sets of these, but not prepared to outlay too much if they need work..
