I want to set my Beocenter 2 up with four passive speakers, but do not know how. Now it plays with a ML/MCL converter and two passive speakers (Beovox 4500).
Thanks in advance.
Do you mean 4 in the same room? You can attach speakers in parallel to the ML/MCL converter - if another room, you need an Xtra speaker kit.
Peter
Thanks for Your answer, Peter. I want four speakers in one room. But what du you mean by attach the speakers in parallel? There is only one socket for powerlink on the ML/MCL converter.
