Set top box
This post has 9 Replies | 0 Followers
Orava
Finland
Posts 991
Orava Posted: Wed, Nov 18 2015 8:42 AM
I must say, if there is One device witch completily destroied my faith to electronics manufacturers ability (or willingnes) to produce good and reliable devices, it is DVB-recorder set-top box.  And now I have to buy new one. Sigh.
Can I say, lucily B&O did not make one of their own...
Andrew
Frinton, UK
Posts 917
Andrew replied on Wed, Nov 18 2015 2:56 PM
Most high street manufacturers are only interested in selling you something new every couple of years and no backward compatibility.
lundmark
Stockholm, Sweden
Posts 105
lundmark replied on Thu, Nov 19 2015 2:14 AM
I can really recommend the Apple TV 4. Not sure what content is available on it in Finland in terms of traditional TV, but around these parts it's quite a lot. Don't need a DVB box for my TV needs.
Millemissen
Flensborg, Denmark
Posts 14,680
lundmark:
And how is the audio and picture quality of the stream compared to the DVB broadcast?
Orava
Finland
Posts 991
Orava replied on Thu, Nov 19 2015 7:18 AM
lundmark:
Mostly I use it to watch programs in more convenient time, only for free broadcasting. Last week I check Samsung DVB Blueray combo, but it has so bad timer,  I returned it.
Main problem with these is sucking software.
kallasr
Germany
Posts 2,562
kallasr replied on Thu, Nov 19 2015 8:45 AM
Still think that Dreambox and VU+ are the most up to date boxes.
IF you are into updating These yourself, lots of Plug-Ins etc.
Harddisk for recording, up to 4 Tuners
Ralf
Orava
Finland
Posts 991
Orava replied on Thu, Nov 19 2015 9:10 AM
kallasr:
Ralf
Trying to keep it simple ;)
Millemissen
Flensborg, Denmark
Posts 14,680
Orava:
In Denmark the Triax DVB boxes are often used.
Either via PUC or as B&O compatible version.
Orava
Finland
Posts 991
Orava replied on Thu, Nov 19 2015 1:01 PM
Unknown here, I will try HDThunder named box (Topform in other countries?)
tournedos
Finland
Posts 7,357
tournedos replied on Fri, Nov 20 2015 12:35 PM
I have used almost exclusively the built-in recording facility of my Sony W6 since I bought it two years ago. It has no problems with HD transmissions and it hasn't failed a single recording yet (except a few due to a bad signal before I replaced the broken antenna wall outlet). The pause function is great too.
The only problem is that you cannot watch another live broadcast channel while it is recording (just one tuner), but I have an external Kodi box for that.
I agree that most set top boxes suffer from stupid software problems. A lot of this is because the broadcasters can use different ways in arranging the EPG data, subtitling, and so on, and these can require all kinds of localized workarounds in the receiving end.
--mika
Page 1 of 1 (10 items) | RSS
