Hi
I am looking at getting a set of BL3s to run off my BV 8-32 ( so I can enjoy movies better ;-) ) but also wondered if I could use the tv like a "switch" to either use the BL3s off the tv, or switch the tv picture off and connect an iphone to the tv to drive the speakers through the tv?
Can I do this or do i need to buy a switch box for the BL3s to swap between input from the tv or iphone please?
I use my tv to drive my existing analogue amp and the signal is a bit low, so not sure if I will also need some form of pre-amp as well.
Any help appreciated :-)
BeoNut since '75
