beocenter 7007 (7002) & beogram 2202
This post has 1 Reply | 0 Followers
foutracks
Posts 8
foutracks Posted: Tue, Dec 15 2015 1:28 PM
(first i'm sorry, I have use google translation because I speak very little English)
Hello,
I recently purchased a BeoCenter 7007 and have various problems with, which is not surprising given the age of the beast :-)
The cell, mmc 3, a suspension problem. Diamond is ok but the suspension is too stiff.
I read here and there that could be remedied with WB40 to soften it, I tried it and it's worse, so I recommend.
So I'm good to send in Germany for up to nine, hoping that my little manipulation is not irreversible for that restoration.
My second problem is at the level of the display, a letter T appears when it is in standby and when I turn it on it remains.
So I have to TPH display when I'm phono (TP1 / TP2 ... when I'm in radio), and 8 in the left part of the screen (moving when handling sound).
This point does not prevent the proper functioning but it's quite unpleasant. At the beginning I had two crystals that seemed grilled, but they have reappeared,
and then some time after the T appeared.
I also have a 2202 platinum Beogram and BeoCenter 7002. Well as you can see I fell into the pot B & O! :-)
I have the greatest difficulty in adjusting the approach of the arm on the disk that is out of adjustment. The cell arises too close to the edge (or side).
Is there a way to remedy that or she automatically calibrates with time? Procedure to be followed?
I hope someone will bring me guidance.
Thank you.
Regards,
Eric
kallasr
Germany
Posts 2,562
kallasr replied on Sat, Dec 26 2015 11:19 PM
Just read this post.
Sendung to Germany (Axel/www.schallplattennadeln.de) is a good idea, you will like what you will get in return.
For your other problems, I cannot help, because I don't understand (and from the little I understand, I suppose I might not be able to help).... sorry.
Ralf
Page 1 of 1 (2 items) | RSS
