Beo 4 "Store" Button
f5434964
Austria
Posts 206
f5434964 Posted: Sun, Dec 6 2015 11:19 AM
Dear friends of beoworld.
The service manual tells me to press "STORE" twice.
I found this function on my Beo4 under "LIGHT" - is this the correct way to send the signal?
Best regards Elmar
Millemissen
Flensborg, Denmark
Posts 14,680
Normally you have to choose/activate A.Setup from the list on the Beo4.
Then you have access to Bass....and S.Store.
Did you try out the Store, that you have - if it works, then :-)
f5434964
Austria
Posts 206
Millemissen:
Thanks for you answer! I've found s.store
I would need the command "STORE" after changing a PCB for reprogramming...
Best regards Elmar
Page 1 of 1 (3 items) | RSS
