Masterlink not connecting
This post has 4 Replies | 0 Followers
jleckenby
Posts 22
jleckenby Posted: Tue, Dec 8 2015 12:47 PM
Hi all,
I have a Beosound 3200 which I recently disconnected the masterlink. After reconnecting I can no longer stream to other rooms. If there anything you have to do to get devices to 'resync' to the masterlink network?
James
valve1
The south of France and occasionally Dublin Ireland
Posts 1,502
valve1 replied on Tue, Dec 8 2015 4:51 PM
Is there a junction box or cable joint near the master link plug ? If there is open it up to see if anything is disconnected.
Is there enough slack on the cable to see if you are getting a good connection when you plug in ?
Millemissen
Flensborg, Denmark
Posts 14,680
Power all devices off - and power them on again....with ML cables all connected.
jleckenby
Posts 22
jleckenby replied on Wed, Dec 9 2015 12:30 PM
Hmm, that made the radio start working again after a few minutes, but the TV one still doesn't work.
It's hard to tell whether its just dead or the masterlink isn't connected. What's the next steps for debugging?
Millemissen
Flensborg, Denmark
Posts 14,680
As mentioned above: check the junctionbox/es.
make sure all wires are connected properly.
Page 1 of 1 (5 items) | RSS
