Good evening,
Is it possible to connect a Beolab 3500 to a Beovision 4-42 / Beosystem 2 without having any audio system connected ? Any help will be greatly appreciated. Thank you.
Any ideas are more than welcome, struggling here
Hello!
Yes, with masterlink cable between them there should be no problem.
You will get sound from the tv that way, or cd/dvd/br if you have a bluray connected to the beosystem.
Good luck :)
Living room: BeoVision 4-50 ACM, Beosystem 3 MK3 with samsung SP-H710AE projector, BeoLab 7-1, BeoLab 6000x3pair, BeoSound 3200, AV & CD cabinett & Beo4.
Lounge: BeoSound 3, BeoVision 7-32 mk5 & Beo4
Kitchen: BeoLab 2000 & Beo4
Master bedroom: BeoVision Avant-32, DVD1, BeoSound Ouverture & Beo4
Guest room: BeoVision 4002, DVD1, BeoSound 2000 & Beo4
