Hi there,
The BV Avant from my parents has a weird problem. The BV reports that there is "no signal" from the Apple TV that has been connected since installation. New HDMI-cable didn't work, using any of the other HDMI inputs didn't work either. Any troubleshooting tips?(I know I should try to connect another product to the BV, but that's not an option atm due to distance and very tech-illiterate parents).
1990:Hi there, The BV Avant from my parents has a weird problem. The BV reports that there is "no signal" from the Apple TV that has been connected since installation. New HDMI-cable didn't work, using any of the other HDMI inputs didn't work either. Any troubleshooting tips?(I know I should try to connect another product to the BV, but that's not an option atm due to distance and very tech-illiterate parents).
1990:I know I should try to connect another product to the BV,
