Hello all,
I have learned that BL5 unfortunately will NOT work wirelessly. I am thinking about buying BO Moment and create music library and hard wire cables to BS9000, Moment and BL5 and maybe buy A9 (for wireless).
Question:
Many thanks and sorry for newbie questions.
Best,
I don't understand the information you were provided regarding the BL5's unable to work wirelessly.... I would imagine that the Transmitter 1 and Receiver 1 combination would work fine with the Beolab 5. Unless there is some intricacy that I'm unaware of.
Connect the Transmitter 1 to the PL outputs of the Beosound Moment, and connect a Receiver 1 to each of the Beolab 5 speakers, and there you should have wireless connection to the Beolab 5.
In order to integrate the Beosound 9000 you'll need a ML/NL Converter.
The Moment works best with Twonky Server software which accesses the Media, be it on a Mac, PC, or on a standalone HD server. You'll download the appropriate Twonky App instance for your equipment, and point it to the folder / directory which houses your media. Many on these forums have always on computers running Twonky pointed to their media directories.
Sal: I don't understand the information you were provided regarding the BL5's unable to work wirelessly.... I would imagine that the Transmitter 1 and Receiver 1 combination would work fine with the Beolab 5. Unless there is some intricacy that I'm unaware of.
Unfortunately it won't work; apparently because some of the data needed for the Beolab 5's to operate (on/off/other?) is not transmitted.
In regards using Twonky/DLNA media server I would limit the use of that to artist / albums that are not on Deezer; saves a lot of tagging / album art hassle; the audio quality from Deezer is fine; I have Beolab 5's too and I do not notice a difference between DLNA (Apple lossless) or Deezer. Of course your ears might be more sensitive than mine ;-).
Peter
