BeoVision Avant & Nvidia Shield TV
This post has 3 Replies | 3 Followers
Roger
Norway
Posts 417
Roger Posted: Mon, Nov 16 2015 12:29 PM
Just a quick note regarding experience transfer to potential Nvidia Shield TV buyers:
1) It works seamlessly with my Avant - the PUC codes and the BeoRemote One mapping is excellent. The codes are available for download through the tv interface, of course. The IR-receiver is easy to identify on the Nvidia box.
2) I did get the Pro edition with the larger hard drive - This was wasted money as I primarily use it for streaming YouTube and Netflix. Get the entry level model if you want to primarily stream content.
3) I tried to use an inexpensive 10m HDMI cable (but still High Speed) and was not impressed. Replaced it with a £125 HDMI cable from Monster and the difference was as clear as 4k :) Funny, but the price for the HDMI cable is about the same as the Nvidia box with the small drive... Only HDMI 1 can be used (requires HDCP 2.2 and HDMI 2.0)
4) Forget about wifi - this box will have to be plugged into your router.
5) B&O recommends setting Netflix to display 4K 23.976 Hz. This is my experience as well.
The Nvidia box will handle all 4k codecs (as you know: YouTube and Netflix use different systems for 4k).
Roger
Millemissen
Flensborg, Denmark
Posts 14,680
Thanks Roger.
And is it (the difference) worth it???
Roger
Norway
Posts 417
Roger replied on Mon, Nov 16 2015 12:49 PM
Not that impressed with the Netflix 4k catalogue and the quality, much more pleased with YouTube - and discovering that there is so much material on YouTube in 4k.
Roger
McHero
Posts 1
McHero replied on Mon, Jan 11 2016 12:53 PM
Thanks for your report and recommendations.
How do you mount the Nvidia Shield? Do you know a solution where the Nvidia Shield is mounted on the back?
Thanks and best regards!
Page 1 of 1 (4 items) | RSS
