I've got a brand new Beolab 10 and I'm wondering if I should remove the stuff below the accoustic lenses. There seems to be a bing piece of sponge in front and two smaller behind it.
https://www.dropbox.com/s/00fdlqdf5qwdwgk/Photo%2015-01-2016%2C%2006%2017%2007.jpg?dl=0
Do not remove the sponges. The larger one is there to reduce resonances caused by the cavity. The smaller ones are to prevent rattling if the wires shake when playing loudly.
Cheers
-geoff
Thanks a lot for the quick and authoritative answer, Geoff! Their fate was almost sealed! :)
