Beovision 7-32 mk3 - unable to tune dtv or to to any channels
This post has 14 Replies | 0 Followers
Simon
UK
Posts 10
Simon Posted: Sun, Jan 24 2016 10:54 AM
Hi
following a move my 7-32 mk3 will not tune any stations on either dtv or tv module
the tv appears to work in all other ways - I can play streaming content through my roku 1 unit, the stand works, I can access all the menus etc
I checked and rechecked the cable set and am confident that these are in the right place
having checked the menus and on connections it had lost its internal stb settings (menu options connections av4) so I selected stb in the hope that this would solve it however I was presented with a 4 page list of stbs from which I had to select arghhhhhh
how do i find which is the right stb?
am I even on the right path?
any help gratefully recieved
 Simon
Millemissen
Flensborg, Denmark
Posts 14,680
Hi and welcome,
do you mean the internal (!) DTV/TV tuners - for this you don't need any STB/PUC.
Or do you have an external box (for DTT) connected?
Simon
UK
Posts 10
Simon replied on Sun, Jan 24 2016 2:32 PM
Hi 😀
Thanks for the reply - I think I do mean the internal dtv/tv tuners
currently the only external connection is a roku 1 which is connected to the camera connection
which makes it more odd that the tv will not tune
any ideas?
Simon
UK
Posts 10
Hi 😀
any ideas?
Simon
UK
Posts 10
Hi 😀
any ideas?
Simon
UK
Posts 10
Hi 😀
any ideas?
Simon
UK
Posts 10
Hi 😀
any ideas?
Mark
London
Posts 1,063
Mark replied on Sun, Jan 24 2016 2:49 PM
are you showing any signal strength in the "menu" ?
Simon
UK
Posts 10
Simon replied on Sun, Jan 24 2016 2:54 PM
signal strength and quality are 0% which is not right
it is connected to a area cable that was working before i connected the B&O
Mark
London
Posts 1,063
Mark replied on Sun, Jan 24 2016 3:03 PM
I know this might sound silly but have you double checked the aerial cable is in the right socket as the TV IN & DVB are close together  (I've done this before as mine is against the wall and I'm blind to any other the connections)
Simon
UK
Posts 10
Simon replied on Sun, Jan 24 2016 3:39 PM
good suggestion...... checked and cable in the right one
Simon
UK
Posts 10
Simon replied on Sun, Jan 24 2016 3:52 PM
but still not working
Mark
London
Posts 1,063
Mark replied on Sun, Jan 24 2016 4:45 PM
Ok thanks for checking .... so we're not getting signal then if the aerial cable is plugged into the DVB socket and there is no signs of signal strength on the menu, if your Roku works fine and nothing else has been changed then there it should be something basic which is good.
You mention you have moved, have you proved that the "new" external aerial is working i.e. with another tv?
Simon
UK
Posts 10
Simon replied on Sun, Jan 24 2016 8:06 PM
have tried with another TV and it works fine - so i think the aerial is working ok
the aerial port has a signal booster connected to it ( the same as at my previous address)
and i have checked the connections themselves and they all look good
this is so frustrating
ps thanks for you help so far
Millemissen
Flensborg, Denmark
Posts 14,680
Would it be possible to post a picture of how you have connected the aerial?
Page 1 of 1 (15 items) | RSS
