I have had the transmitter 1 for about a year now and until now it has worked flawlessly. However after changing to a new internet router that supports both 2,4 and 5 ghz it now turns it self and the speakers on all the time. Do you know if there is a way around this?
Hi Sibbi,
Could it be something else?
I use a Transmitter 1 and an Apple Time Capsule as a router, which also runs on 2.4 and 5 ghz - no problem.
I wonder if you should reset your T1 and go through the entire process of pairing again ?
Good luck?
Thanks for your reply. It turns out that if I move the router further away from the Transmitter than it is OK. But when they are close to each other than this starts happening. Beosupport say it has something to do with the RCA inputs being sensitive.
