My Beocenter 7700 which had been in my family since day one and has travelled with my sister to Connecticut and back and was given to me because it stopped working. I replace a leaky cap and it works perfectly now, but I need new hinges for the program lid and a belt for the tape deck. Does anyone know where I could find these things?
Chris
Martin (Dillen on site) can get you new belts and instructions on how to fit them. The hinges will be a problem.
Peter
Hi ChrisK43,
I saw hinges for BC7700 here:
https://type181.files.wordpress.com/2015/06/3011011.jpgon ebay, but not sure if it was for 7700 Beocenter
or try someone with 3D printing technlogy, for example: http://beolover.weebly.com/parts.html
I got the new belts from Martin.(Thank you). Now I have a new problem. This system was working great now when I plug it in all I see on the display is the recording level, and none of the buttons work. Any suggestions on what I do to fix this?
Hi
There were an old topic on this forum, try to search. The problem could be in the microprocessor.
