Can anyone tell me if its possible to get V.AUX as a source function on my Beolink 7000 remote?
Mine is the later CDV version it seems, as pressing OTHER for sources brings up CDV only can cannot find a V.AUX.
As i have a STB-C control module fitted to control my Humax digtal TV box, i need V.AUX as a source button to activate the television.
Any ideas? is it possible to use another source to control the STB-C module ? its in a AV9000, basically a upmarket MX beovision.
really want to use the Beolink 7000 to turn on the television and control it.
Phil
