BEOMASTER 900K Dial Lamp Fuse Type
craigdmb
Posts 2
craigdmb Posted: Tue, Feb 9 2016 8:23 PM
Hi All,
have purchased a beautiful Beomaster 900K. It is in fantastic condition. Everything works fine except for the dial lamps. Figuring it was the globe, I have changed these, however I've read up on the forums that there is a Dial Lamp Fuse. Ive located it and it seems to be a miniature type fuse. Can someone please advise what type is required? The mains fuses are fine appear to be 5X20, just having trouble figuring out what the smaller fuse is.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Feb 9 2016 8:51 PM
The dial lamp fuse is also a 5x20mm type (sits on the large main board).
Same type as the two mains fuses (on a small board at the side of the chassis) - only with a different rating.
Typically, the dial lamp fuse holders will have disintegrated due to oxidation.
They turn green and crumbly and will also need replacing.
Curiously, the mains fuses holders are always fine.
craigdmb
Posts 2
craigdmb replied on Wed, Feb 10 2016 8:23 PM
Great thanks Martin very helpful worked a treat :)
Ben_S
UK
Posts 631
Ben_S replied on Fri, Feb 12 2016 8:15 AM
Very common problem this. Had to change the fuse holder on mine on Martin's advice and it worked really well since!
Ben
Page 1 of 1 (4 items) | RSS
