Dear all,
do the beogram and beomaster 6500 units have a voltage switch? the unit I am considering to use in Australia (220-240V) originates from USA (120V). If there is no switch should I purchase a step down voltage unit?
thanks for for assistance inadvance
Sam
No, they don't have voltage switches but you could get an electronics technician to change the tappings on the mains transformers.
Regards Graham
Dear Graham,
Many thanks for your help.
