I guess that many will be happy. It seems beautiful. I cannot wait to see it in flesh!
Just been into @Sheffield to pick up a pair of black H8s (in the bag to the right in the pic below). More of those later. The new black Beolit15 was also in-store. As is often the case it looked even better in real life. Very classy indeed and the soft/matt finish on the top looks incredible in black.
And it still sounds fab of course. Just wish I had a spot to put one.
Stunning!
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Just one more up close....
The white B&O logo stands out and looks good.
I think there's a mistake on BeoPlay website as it says that it has 'AIRPLAY' as well as Bluetooth!
Paul W: I think there's a mistake on BeoPlay website as it says that it has 'AIRPLAY' as well as Bluetooth!
Where are you looking Paul? The snip below of the beoplay website spec shows just Bluetooth 4.0 for connectivity
Duels: Paul W: I think there's a mistake on BeoPlay website as it says that it has 'AIRPLAY' as well as Bluetooth! Where are you looking Paul? The snip below of the beoplay website spec shows just Bluetooth 4.0 for connectivity
It actually does!
In the Connectivity section if you scroll the page, there is even an Airplay icon, and when you click that its as that you can stream using Airplay.
BIG mistake. I will post that on their Facebook so that they are aware
Hiort: It actually does! In the Connectivity section if you scroll the page, there is even an Airplay icon, and when you click that its as that you can stream using Airplay. BIG mistake. I will post that on their Facebook so that they are aware
Its "only" wrong on the webpage. On the mobile device its correct.
Page 4 Duels - under CONNECTIVITY
I bet that it would look nice with the Light Natural leather strap option.
Paul W: Page 4 Duels - under CONNECTIVITY PLAY IT YOUR WAY
Got it Paul. Bit careless.
Paul W: I bet that it would look nice with the Light Natural leather strap option.
Yes I think it would. Interchangeable straps is a good feature.
What a shame that they didn't introduce the Black Copper to it.
Yes very bizarre Duels as it should of been proof read a few times by the marketing manager & his team before going 'live'.
Hiort: Hiort: It actually does! In the Connectivity section if you scroll the page, there is even an Airplay icon, and when you click that its as that you can stream using Airplay. BIG mistake. I will post that on their Facebook so that they are aware Its "only" wrong on the webpage. On the mobile device its correct.
I posted on Beoplay Facebook. They thanked me for bringing that up, and have now corrected the webpage.
Great teamwork Beoworld :)
Hi Julian, hope you are enjoying the new H8. The black 15 is proving to be very popular and the dem of the twin 15 stereo set up is stunning! If you haven't already picked up a copy of the new book I have one here for you...
