BeoSound 1 Password Recovery
jjdillon92234
Posts 2
jjdillon92234 Posted: Fri, Feb 19 2016 4:07 AM
My BeoSound was recently disconnected while TV repairs were being done. I bought it over 3 years ago and didn't write down the password. Does anyone know how I can clear or recover the password ?
Thank you.
Millemissen
Flensborg, Denmark
Posts 14,680
If you bought it from a regular dealer, and you did not change the PIN, the dealer might still have it.
Otherweise he might help getting a mastercode for resetting the PIN.
N.B. Are you sure, that it was not written down on your receipt - dealers often do that.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Feb 19 2016 10:16 AM
You will need to contact B&O to get the code(s) you need.
For this you will need to bring the purchase receipt, preferably the original. You will have to get this
from the previous owner.
B&O will then check if the item has been reported stolen and, if everything is fine, give you the code.
B&O things are among the most stolen items in the world. Without the codes the items are pretty much worthless.
This is B&Os way to counteract for trading with stolen goods.
Beoworld neither can - nor will - give out codes.
Page 1 of 1 (3 items) | RSS
