Hi
My 9300 is almost dead, when I plug it in 230 volt I hear a relay switch in after 1-2 sec. and there is a little light in the middle og the watch. After approx. 10 sec. the same relay switching again.
When the relay is on I can messure 230 Volt on the Big trafo comming from the little trafo.
Also if I manual open the sliding gates to Tape and CD they close when I plug it to 230 Volt
All 7 Fuses are OK but the 9300 is dead.
What do I do
BR Kurt
