Hi all,
I just got hold of a BeoMaster 5500, my first vintage B&O piece, and I really like it. Unfortunately the previous owner could not find the MCP.
My problem now is that the tuner is set to AM and I want to switch it to FM reception. I have scanned through the BeoLink 1000 manual and it says that this can be achieved by pushing the "TURN" button. Unfortunately, non of my BeoLink 1000 remotes has a TURN button:(
I also tried the "TURN" functionality on my B&O without success (apparently this only applies to BeoCord on the Beo4).
Does anyone know how to change the band to FM without MCP? Is it even possible?
After 15 minutes more googling, I found the solution the works by pushing SHIFT + SOUND...
