Hi
I have been racking my brain ... I remember seeing on the B&O FAQ site a while back a compatibility list of products vs the BeoRemote One, and now i can't seem to find it.
Does anyone have this list or a link to it by any chance?
I have just bought an A9 MK2 Black and was wondering how to use the BROne with it.
It's being delivered during the week.
Michael.
You can not. MK II does not support ir.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Maybe the new BR1/BT, that is said to come soon, will bring new possibilities???
Thanks Hiort and MM
Maybe I will get an essence wheely and use that with the A9.
But you can use the BR1 with the PlayMaker I'm thinking, I'm quite sure that was on that list i looked at in the FAQs
Aussie Michael: But you can use the BR1 with the PlayMaker I'm thinking, I'm quite sure that was on that list i looked at in the FAQs
That should be possible. At least if you set the BR1 in Beo4 mode.
