Hi. Can anyone tell me the difference between scaler modules ?
If am going to have a new DVB-T2 module installed, and I want to connect to the DVI plug for
having a better picture, but in the instruction manual from Bang & Olufsen it is mention that the
scaler module must be version E, but my module is version B.
I have been told from another Bang & Olusen workshop, that the have installed many modules also when scaler module is version A, and it works no problem.
My quistion is: Why does Bang & Olufsen say Version E ?? when is works great on a version A scalermodule ?
Thanks and regards
PH
