Hi:I'm wondering if anyone knows if GUIDE CLAMP for the BEOSOUND 9000 MK1 Part Number 3014134 is still available? The teeth on the one I'm replacing is worn, and so the gear is skipping.
B&O seems to have modified the part in later versions of the 9000.
The original part has a white strip reflects light to the opto-coupler board.
The new one has a molded groove with a U shaped opto-coupler. This version doesn't clear the opto-couplers on the PCB of the MKI.
Anyone have any experience working on this?
Thanks,
Derek
