How to Use a Beogram 7000 wirelessly or from a distance - Sound only required
ergonomist
Posts 12
ergonomist Posted: Tue, Mar 29 2016 9:38 PM
Hello,
I'm new to this.
i have a Beogram 7000 and a Beosound 3200 which unfortunately for a while I need to have at separate ends of a room. Can I connect them using the Beolink Wireless 1 system? Using the transmitter for the Beogram and the receiver for the Beosound?
Can I connect them using only the din plugs or would I need something else?
Also, if not, does anyone know another piece of equipment that could link the 2 wirelessly so I can continue to use whilst they are 'separated'
many thanks
Lee
elephant
AU
Posts 8,219
elephant replied on Wed, Mar 30 2016 10:20 AM
No Lee. The protocol over the wireless is master link; not data link which is what I believe is used between a Beo-peripheral and its Beo-master
Others may have bright ideas to get you what you are asking.
I suggest you change the title of the topic as there are very few BeoLink wireless users.
Perhaps something like "how to drive a beogram at long distance?"
BTW I have just had a thought ... For others to shoot down:
Can a BeoLink Active in PC mode support the Beogram and talk over the BeoLink Wireless to the Beomaster ?
BeoNut since '75
Millemissen
Flensborg, Denmark
Posts 14,680
elephant:
1: Anything connected to the PC-input (of the Active) can only be accessed locally.
2: I see no reason why not - but the Active would still only draw from the sources of the BeoMaster.
beojeff
USA
Posts 2,012
beojeff replied on Wed, Mar 30 2016 5:37 PM
You might get the sound when connected to the PC input of the Active, but you would most likely lose the datalink control of the Beogram. I tried connecting a Beogram to the AUX input of an AV7000, but the datalink control was lost. You need the turntable connected to a BeoMaster in order to get the datalink control.
ergonomist
Posts 12
Thanks for your help.
I've renamed and will wait and see if anyone has any bright ideas
I only really want to send the sound to the Beosound,control of the Beogram is not an issue.
beojeff
USA
Posts 2,012
beojeff replied on Wed, Mar 30 2016 8:34 PM
Since datalink is not a concern, perhaps search for a wireless RCA transmitter and receiver. I just found one on Amazon for $71 USD.
beojeff
USA
Posts 2,012
beojeff replied on Wed, Mar 30 2016 8:36 PM
I'm also finding them for half that price.
Page 1 of 1 (7 items) | RSS
