Hi i wanna add some new capacitors to my beovox p45 speakers. It has 3 on the board 2 small reading +8 35v and one big reading +25 35v.
Can i use these new ones:
http://www.netsound.dk/da/jantzen-cross-cap-400-v/231-8-uf-cross-cap-mkp-kondensator-jantzen.html
http://www.netsound.dk/da/jantzen-cross-cap-400-v/302-27-uf-cross-cap-mkp-kondensator-jantzen.html
There isnt any with exact numbers matching.
the crosower
Original electrolytic caps are +- 20% so 6.8 uF and 22 uF 35 or 50 V will do, dont by anything fancy and expensive you wont hear any difference, or ask Martin (Dillen)
wrong post sorry
For crossovers,
It is a well known practice to replace electrolytic with film capacitors instead.
Dayton and Solen are the ones I have in mind but you have lots of manufacturers.
Regards,
Rasmussha: Hi i wanna add some new capacitors to my beovox p45 speakers. It has 3 on the board 2 small reading +8 35v and one big reading +25 35v. Can i use these new ones: http://www.netsound.dk/da/jantzen-cross-cap-400-v/231-8-uf-cross-cap-mkp-kondensator-jantzen.html http://www.netsound.dk/da/jantzen-cross-cap-400-v/302-27-uf-cross-cap-mkp-kondensator-jantzen.html There isnt any with exact numbers matching.
