Hi
I have just finished restoring my begrime 1200. Everything is in order, except, that the tonearm does not lift. When I press the start button, it slides towards the edge of the record, but bumps into the side/edge of the record, because the arm is not lifted. I can't seem to find any thing that looks like a lifting mechanism? Can anyone point me in the right direction?
-Kasper
the lifting mechanism is a disk that surrounds the arm pivot and this plate raises and lowers interacting with a post that goes through the tonearm that is adjustable you should be able to see a flat point head of the post a at the back of the tonearm
Best of luck
