Hello
I bought a cool beovision MX5500 some years ago to play with retro consoles.
The TV is working great but during certain game sequences (bright flash, 3D map rotation...), some thin black lines are appearing briefly in the middle of the screen.
It occurs above all (maybe only) with consoles which are connected with composite.
I precise I use PAL consoles.
Would you know where the issue may come from? Maybe the tv is too old...1992 I think.
Thanks for your feedbacks!
