wiring on beocenter 7002
Landervm
Posts 4
Landervm Posted: Fri, Mar 25 2016 8:03 AM
I have recently acquired a Beocenter 7002. Everything is working, except the turning table. I opened up this device and compared it to a working Beocenter 7000. I have noticed that there is no wiring to the pick-up arm connection (see picture 1)
On the Beogram 7000 I can see that there are 5 cupper wires that come together and seem to be squeezed into the pick-up arm connection (see picture 2). Is that really what I have to do, or is there more to it than meets the eye?
What kind of wire should I be using?
Thank you for your help,
A B&O repair newbie...
163329.aspx
163328.aspx
ProGram
59269 Beckum, Germany
Posts 383
ProGram replied on Wed, May 4 2016 4:48 PM
In any case, you will have to disassemble the tone arm bearing. I don't know, if the contacts for the pick-up are detachable for soldering ( the next generation of tone arms are filled with glue and can not be worked on). The wires are perhaps of enamelled copper wire. If not, you will ned a complete new tone arm
Chris
Page 1 of 1 (2 items) | RSS
