BeoLab Penta - Difference between Speaker Link and Line ?
bdugardin
Posts 89
bdugardin Posted: Wed, May 18 2016 6:33 PM
Dear All,
I'm trying to connect a non-B&O amp to my BeoLab Penta.
First i've connect the amp in Line plugs with a converter between amp and BeoLab Penta. It works fine, but when i shut down my amp, it send background noise to the Penta ... curious.
I want to try to connect the amp to the Speaker link plugs of the Penta. What's difference between Line and Speaker Link connection on Penta ?
Lee
Newcastle upon Tyne UK
Posts 734
Lee replied on Wed, May 18 2016 11:27 PM
Hi.
The speaker link inputs are attenuated and offer the lowest sound quality. Basically you connect the speaker outputs of your amplifier to the speaker link sockets on the Pentas and the already amplified signal is attenuated to line level and then re-amplified.
Lee
bdugardin
Posts 89
bdugardin replied on Thu, May 19 2016 8:01 AM
Hi Lee,
Thank you very much for this very clear reply !
Page 1 of 1 (3 items) | RSS
